Retired_Member
Jul 27, 2019Confusing/conflicting technical specifications on the RAX75 specifications page...?
On the RAX75 technical specifications page (https://www.netgear.com/home/products/networking/wifi-routers/rax75.aspx) Under the "WIFI TECHNOLOGY" section it says: 2.4GHz AX: 4x4 (Tx/Rx) 256 QAM 40M...
schumaku
Jul 29, 2019Guru - Experienced User
In case they make 920 Gb/s om 2.4 GHz I am going to take some 8-)))))
The RAX75 is a software-wise "scaled down" variant of the RAX80 - the 2.4 GHz AX interface is limited to 256 QAM, so "only" 0.92 Gb/s - and intended for specific sales channels like Costco. 4.8 + 0.92 makes 5.7 or AX5700.
The "2.4GHz AX: 4x4 (Tx/Rx) 1024 QAM 40MHz, up to 1.2Gbps" is wrong, and applies to the RAX80 only.
The "2.4GHz AX: 4x4 (Tx/Rx) 256 QAM 40MHz, up to 920Gbps" is also wrong - it should be "2.4GHz AX: 4x4 (Tx/Rx) 256 QAM 40MHz, up to 0.920Gbps".
Netgear's CHT marketing is as poor as Netgear's CHT engineering and QA.
