Retired_Member
Jul 27, 2019Confusing/conflicting technical specifications on the RAX75 specifications page...?
On the RAX75 technical specifications page (https://www.netgear.com/home/products/networking/wifi-routers/rax75.aspx) Under the "WIFI TECHNOLOGY" section it says: 2.4GHz AX: 4x4 (Tx/Rx) 256 QAM 40M...
Christian_R
Jul 30, 2019NETGEAR Employee Retired
Hello hctb,
Thanks for bringing this to our attention. I have notified the team to have this corrected. The correct information is listed below:
2.4GHz AX: 4x4 (Tx/Rx) 256-QAM 40MHz, up to 920Mbps
5GHz AX: 4x4 (Tx/Rx) 1024-QAM 160MHz, up to 4.8Gbps
Christian
- chedoggNov 20, 2019Aspirant
On the very last page of the .pdf user manual from the product page, the listed WIFI signal rate as 1.2Gbps for 2.4GHz 1024 QAM 40MHz.
Is this also incorrect?Product page: https://www.netgear.com/support/product/rax75.aspx#docs
PDF Manual: http://www.downloads.netgear.com/files/GDC/RAX75/RAX75_UM_EN.pdf
