Retired_Member
Jul 27, 2019Confusing/conflicting technical specifications on the RAX75 specifications page...?
On the RAX75 technical specifications page (https://www.netgear.com/home/products/networking/wifi-routers/rax75.aspx) Under the "WIFI TECHNOLOGY" section it says: 2.4GHz AX: 4x4 (Tx/Rx) 256 QAM 40M...
chedogg
Nov 20, 2019Aspirant
On the very last page of the .pdf user manual from the product page, the listed WIFI signal rate as 1.2Gbps for 2.4GHz 1024 QAM 40MHz.
Is this also incorrect?
Product page: https://www.netgear.com/support/product/rax75.aspx#docs
PDF Manual: http://www.downloads.netgear.com/files/GDC/RAX75/RAX75_UM_EN.pdf
