billrenn
Jan 10, 2022Guide
Connect both USB storage drive AND printer to Nighthawk RAX42 (only 1 USB3 port)?
Just installed new Nighthawk RAX42 (AX4200 5-stream WiFi6) router, and successfully set up an external storage drive in the single USB 3.x port. Updated Windows 10 on most of the networked machines,...
Jan 10, 2022Guru - Experienced User
I've heard of people using a usb hub to connect more than 1 drive. Can't say if I've read of people connecting hard drives and a printer.
A usb hub is pretty cheap and if it didn't work, you could always return it.
