billrenn
Jan 10, 2022Guide
Connect both USB storage drive AND printer to Nighthawk RAX42 (only 1 USB3 port)?
Just installed new Nighthawk RAX42 (AX4200 5-stream WiFi6) router, and successfully set up an external storage drive in the single USB 3.x port. Updated Windows 10 on most of the networked machines,...
michaelkenward
Jan 11, 2022Guru - Experienced User
Did this router replace something else?
I ask because there is on possible solution that I haven't seen mentioned before.
Netgear sells wifi extenders that support a USB printer. EX6200 for example.
Probably not worth investing money to get this feature, but if you have an old router lying around that does support a USB printer, it might be worth putting that into AP mode and seeing if the printer works.
This isn't billed as one of the features that fall over when a router goes AP.
