dehinson64
Dec 07, 2022Guide
Connect more that 2 USB 3.0 Devices on AX8
Hello, I was wondering if I used a true USB 3.0 splitter, could the AX8 recognize and configure the additional device in ReadyShare?
- Dec 14, 2022
This one...
UGREEN USB 3.0 Hub, 4-Port USB Hub with 3ft Extension Cable, High-Speed Portable USB Splitter for MacBook Air, Mac Mini, iMac Pro, Surface Pro, XPS, PC, Flash Drive, Mobile HDD
I'd like the number of positive reviews and that Mobile HDD was supported. So, I thought this might work.... and it did.
Dec 07, 2022Guru - Experienced User
I've seen users doing that and it working but I can't guarantee it as I personally haven't. Just make sure you use a powered hub as doubtful the usb power is enough for more than 1 device.
