dehinson64
Dec 07, 2022Guide
Connect more that 2 USB 3.0 Devices on AX8
Hello, I was wondering if I used a true USB 3.0 splitter, could the AX8 recognize and configure the additional device in ReadyShare?
- Dec 14, 2022
This one...
UGREEN USB 3.0 Hub, 4-Port USB Hub with 3ft Extension Cable, High-Speed Portable USB Splitter for MacBook Air, Mac Mini, iMac Pro, Surface Pro, XPS, PC, Flash Drive, Mobile HDD
I'd like the number of positive reviews and that Mobile HDD was supported. So, I thought this might work.... and it did.
michaelkenward
Dec 08, 2022Guru - Experienced User
It might depend on the USB devices you use.
I haven't tried a splitter, but I have a Seagate 8 TB Backup Plus Hub connected to an R7800. The Seagate has two USB ports that the router happily recognises. So I have 4 USB ports running off a single router.
dehinson64
Dec 08, 2022Guide
Hello,
So, I want to attach two WD Elements. Would this work without a powered splitter? I am only using to do backups and streaming. I figure that if the sharing of the 6GB, making 3GB per WD Element should not adversely affect streaming to one TV or doing a night backup of the C: Drive.
What do you think?
