dehinson64
Dec 07, 2022Guide
Connect more that 2 USB 3.0 Devices on AX8
Hello, I was wondering if I used a true USB 3.0 splitter, could the AX8 recognize and configure the additional device in ReadyShare?
- Dec 14, 2022
This one...
UGREEN USB 3.0 Hub, 4-Port USB Hub with 3ft Extension Cable, High-Speed Portable USB Splitter for MacBook Air, Mac Mini, iMac Pro, Surface Pro, XPS, PC, Flash Drive, Mobile HDD
I'd like the number of positive reviews and that Mobile HDD was supported. So, I thought this might work.... and it did.
Dec 15, 2022Guru - Experienced User
Looks good. The only thing I'd be careful of is that isn't a powered hub. And those routers don't put out a ton of power over usb. So if you're devices aren't powered, you might not have enough to run multiples. (just to be careful when plugging in more devices)
dehinson64
Dec 15, 2022Guide
Both of the WD Elements are powered enclosures. So, I believe I am in good shape. However, if need to power the USB HUB, it does have an option to do so...
- michaelkenwardDec 15, 2022Guru - Experienced User
I just received a USB - SATA adapter that also has the option to plug in a 12 volt supply.
Nice to receive this sort of thing without yet another power brick. I already have stacks of the things.
- plemansDec 15, 2022Guru - Experienced User
Nice! Rare to see that anymore with the option to add it. good buy
