Retired_Member
Jul 12, 2021Connect MR60 Satellite to Orbi AX6000 router
Does the new Orbi AX6000 router connect to MR60 WiFi6 Satellite? The existing MR60 Satellite is a small cabinet hence do not want to replace it with another Orbi AX6000 Satellite. Thanks
Jul 15, 2021Guru - Experienced User
the orbi systems and the MK sysstems are not compatible.
They won't integrate together.
- Retired_MemberJul 15, 2021
Thanks for taking time to reply... much appreciated.
