tev1967
Aug 17, 2023Aspirant
Connected Device Limit (RAX10)
Hi, stupid me didn't realise this router had a limit of 20 connected devices, I've got almost double that. Is there a simple, inexpensive way to extend it's capacity for Wi-Fi connected devices? Than...
Kitsap
Aug 18, 2023Master
tev1967 wrote:Hi, stupid me didn't realise this router had a limit of 20 connected devices, I've got almost double that. Is there a simple, inexpensive way to extend it's capacity for Wi-Fi connected devices? Thanks
I recognize the product data sheet indicates a limit of 20 devices. Screen snip attached. An extender is not going to help.
Have you actually run up against that 20 device limit? Make sure your configuration provides a DHCP address pool of sufficient size.
It may no longer be limited to 20 if you have installed the current firmware version.
