Bmparks03
Mar 14, 2022Follower
Connected to Modem I get 800 , when connected to RAX200 I get 400.. HELP
Just wondering why my top of the line router is cutting my internet speeds. I’m not sure what to do.
Mar 14, 2022Guru - Experienced User
what firmware version are you on?
What modem/gateway are you connected to?
What site are you testing on?
Make sure to disable qos, access control traffic monitoring, and parental controls.
Then reboot and test speeds
