Swayzman's avatar
Swayzman
Follower
Jun 06, 2020
Connecting a Netgear Nighthawk R7000 with a Nighthawk MR60
Trying to connect my Nighthawk R7000 to MR60 mainly for the wired connections that are needed for non WIFI devices
1 Reply
  • plemans's avatar
    If you're going modem----mr60-----r7000, you'd want the r7000 in access point mode. Also make sure the wifi's are on different channels so they don't conflict.
    I'd recommend just buying a cheap unmanaged switch.
