Padishah
Oct 28, 2021Tutor
Connecting a RAX120 to the modem via ethernet switch
I had posted this question in, it appears, the wrong forum. It was suggested that I move it here. I need to move my router and a couple of router connected devices to a shelf some distance away. ...
- Nov 04, 2021
Thanks to all who replied with various solutions to my issue. In the end, I decided to try the powerline device. I'm not in a high interference area and power is rather stable so went that way for now. I've been up and running for about a week now with no issues that I've noticed.
That said, I'll keep the EdgeRouter X/DMZ configuration in mind if this doesn't work out in the long run.
Oct 28, 2021Guru - Experienced User
If you mean wireless bridge, I believe so.
Check the user manual for these options. Most RAX routers have AP mode at least. The last RAX80 I had also supported wireless bridge mode.
- FURRYe38Oct 28, 2021Guru - Experienced User
My bad, posted wrong info.
It is if thats the only device connected to the switches. Nothing else can be connected to the switches. It would not be recommended.
Optimal configuration should be:
Internet Modem --> Router internet port --> Ethernet Switch
FURRYe38 wrote:
If you mean wireless bridge, I believe so.Check the user manual for these options. Most RAX routers have AP mode at least. The last RAX80 I had also supported wireless bridge mode.- PadishahOct 28, 2021Tutor
Thanks for the responses. This is basically what I concluded. I think I'm stuck then.
- plemansOct 28, 2021Guru - Experienced User
got an old gigabit router sitting around?
I've went modem---->old router (wifi disabled)---->switches/devices-----Router (in AP mode)
I've done this more than 1 time in homes that have to have the modem in a location not optimal for a wireless router but needing switches/ethernet connections there.
