Padishah
Oct 28, 2021Tutor
Connecting a RAX120 to the modem via ethernet switch
I had posted this question in, it appears, the wrong forum. It was suggested that I move it here. I need to move my router and a couple of router connected devices to a shelf some distance away. ...
- Nov 04, 2021
Thanks to all who replied with various solutions to my issue. In the end, I decided to try the powerline device. I'm not in a high interference area and power is rather stable so went that way for now. I've been up and running for about a week now with no issues that I've noticed.
That said, I'll keep the EdgeRouter X/DMZ configuration in mind if this doesn't work out in the long run.
Oct 29, 2021Guru - Experienced User
If you use this configuration:
Modem --> EdgeRouter --> switch --> (existing cable) --> RAX 120
You'll be in double NAT condition, which isn't recommended, however to elleaviate this condition, use the EdgeRouters DMZ for the RAX in router mode if you want to use router mode.
Padishah
Nov 04, 2021Tutor
- FURRYe38Nov 04, 2021Guru - Experienced User
Please mark your thread as solved so others will know.
Enjoy. - PadishahNov 04, 2021Tutor
Sorry to be blind but how/where do I mark a thread as resolved. I'm not seeing it in the Community UI.
Oops looks like you already did. No worries.
Enjoy.
