Petrichor
Jan 17, 2023Aspirant
Connecting a Seagate USB 3.0 hard drive to my Nighthawk AC 1750 router.
I have my Drive plugged in to the router but I don’t see it anywhere. I’m not sure if I need some other software or what exactly I need to do but it never shows up on my Mac OS 13.1 network Thanks ...
Jan 17, 2023Guru - Experienced User
What format is the drive in?
https://kb.netgear.com/24059/What-are-the-USB-drive-requirements-for-ReadySHARE-on-my-NETGEAR-router
https://kb.netgear.com/24060/How-do-I-connect-a-USB-drive-to-my-Nighthawk-router
Petrichor
Ahh…. It is a macOS extended, case-sensitive, journaled. I’m gathering that’s probably the issue. Unfortunately that’s my backup drive and I am kind of stuck as to how to save my data and yet reformat the drive
Thanks for your response.
