Gaz123456789
May 18, 2024Aspirant
Connecting cables for new router
I currently have a Nighthawk AC1900 router (D7000v2) that has a DSL (rj11) cable plugged in to the back, I'm looking at getting a Nighthawk AX5 RAX42, this does not have the connection for a DSL cabl...
- May 18, 2024
Amazing, thank you for the speedy reply, I guess my currant router has one built in?
michaelkenward
May 21, 2024Guru - Experienced User
Gaz123456789 wrote:
You say to use the DSL router as a modem only, After setting it up as a modem, would I be able to use the AP feature within the settings? the whole reason behind me asking is the original question is because I would like to extent my wifi range. I would have the RX42 at one end of my house with the AC1900 the other.
Do you mean you want to use the D7000v2 as an AP?
In modem only mode, there is no wifi from the D7000v2.
An alternative is to use the RAX42 in AP mode.
That needs a wired connection between the D7000v2 and the RAX42.
There are ways to use the D7000v2 as a modem/router with the RAX42 as a second router.But they are a bit complicated. I have a similar arrangement with a BT modem/router in front of an MR90 router.
A better setup might be to forget about the RAX42 and to go for a Mesh router, something in the Orbi or MK range with an extra satellite or two to spread the wifi. That would give a much more manageable and reliable wifi network than trying to get two independent wifi networks to play nicely together.
Gaz123456789
May 21, 2024Aspirant
Hi, Thanks again for the quick response,
I currently have a D7000v2 in the middle of my home with a vodafone modem router at the end of my home to extend the wifi (the house is hardwired to most rooms from the office). The router is hardwired and configured to the same wifi to extend it. (no AP mode, just what I found online to extend range)
The end of the house with the Vodafone router, the wifi drops in and out and very unstable and I'm forever logging back into the wifi on my phone.
I think I will go for the alternate method you suggested and use the RAX42 in AP mode or see if I can buy another D7000 and use that in AP mode. I hope that will improve over the currant set up I have. I'm happy to give that a go over buying a mesh system. (hey at least I might learn something).
Thank you for your help and answering my questions.
- michaelkenwardMay 22, 2024Guru - Experienced User
Where did that vodafone modem suddenly come from? Likewise the wired ethernet.
It is a completely different arrangement from a D7000v2 in DSL mode.
Buying another one of those seems pointless if you want to get better wifi. I would start again with a more complete explanation of what is going on at your end. That means telling people just which Vodafone modem you have.
My inclination would be to dump the D7000v2 completely and add a more modern router/AP.
