TommieFantine
Nov 12, 2023Follower
Connecting MacBook Pro with ethernet cable to AX4300
To connect directly my MacBook Pro to the AX4300 router the instructions say to use an Ethernet Cable, but this requires an adapter to the Thunderbolt 3 port, yet when I try this the computer does no...
michaelkenward
Nov 12, 2023Guru - Experienced User
TommieFantine wrote:
To connect directly my MacBook Pro to the AX4300 router the instructions say to use an Ethernet Cable, but this requires an adapter to the Thunderbolt 3 port, yet when I try this the computer does not see the router. What am I doing incorrectly? I am using a tomtoc L2013G adapter.
That's really down to your MacBook and the Adapter. Not really something that Netgear can help with.
To upload the latest software for the router the instructions state I have to connect directly via ethernet cable.
That is certainly the best option, but there are ways around it.
If you can connect to the RAX45 over wifi – it isn't really an AX4300 because there are too many of those to tell them apart – you should also be able to point a web browser at the graphical user interface (GUI). Same instructions as for the wired update.
Start by downloading the firmware to your MacBook. Then follow this advice:
How do I manually upgrade firmware to my NETGEAR router? | Answer | NETGEAR Support
