daveyj6607
Mar 25, 2025Aspirant
Connecting Netgear RAX80 to another router.
Hi I live in a rural community with no fibre and poor copper connection to ISP's. Instead we have a provider that uses 4G/5G technology and a small dish on the house to connect to a mast a few miles...
Mar 25, 2025Guru - Experienced User
If the new ISP router has a DMZ or IP pass thru option feature, then you can use this on there router for the IP address the RAX gets from the ISP router. Check with the ISP on configuration of there routers DMZ feature.
Or configured AP mode on the RAX router and use there router as your host router with it's wifi radios disabled.
daveyj6607
Mar 27, 2025Aspirant
I will try that, thanks
- KitsapMar 28, 2025Master
If you find your ISP router is locked down to prevent configuration changes, set your RAX80 operation mode to access point and make sure it is physically positioned several feet away from your ISP router.
