daveyj6607
Mar 25, 2025Aspirant
Connecting Netgear RAX80 to another router.
Hi I live in a rural community with no fibre and poor copper connection to ISP's. Instead we have a provider that uses 4G/5G technology and a small dish on the house to connect to a mast a few miles...
daveyj6607
Mar 27, 2025Aspirant
I will try that, thanks
Kitsap
Mar 28, 2025Master
If you find your ISP router is locked down to prevent configuration changes, set your RAX80 operation mode to access point and make sure it is physically positioned several feet away from your ISP router.
