bearace
Nov 30, 2020Tutor
Connecting Nighthawk RAX 80 to Telstra Gen 2 modem ( Arcadyan LH1000)
Router Nighthawk AX 8 Wifi router Modem Telstra Gen 2, Arcadyan LH1000, with telephone backup via sim card How do I connect the nighthawk RAX 80 router to the Telstra Gen 2 Modem and still have fu...
- Dec 02, 2020
Not all device makers code properly. Which is why you might be having issues with dmz.
One thing to check is the IP address. Make sure the Arcadyan doesn't have the same IP address as the netgear if settingup dmz.
If they both used the same IP address,DMZ isn't going to work. You'd have to change it. For example
Arcadyan at 192.168.1.1
Netgear at 192.168.2.1
options?
1. Try the above
2. Leave it in a double nat. can cause issues with some devices
3. Put the netgear in AP mode. you do lose some features you don't want to lose but you might be caught in a catch-22 of damned if you do, damned if you don't.
bearace
Dec 01, 2020Tutor
Thanks for the advise but unfortunately no luck.
Logged into telstra modem, found DMZ under firewall, checked box and assigned IP address to router IP address.ie,xxx.xxx.0.4
Unchecked DHCP server and logged out.
Went into router, unchecked from AP, checked DHCP server, assigned IP address as per modem and logged out.
Restarted Modem, then router the PC couldnt access either device, no internet or router.
Restarted Router, then modem, then PC no changed.
After many hours of trying still no luck. Have had to do full reset of both modem and router, several times plugging each into the PC individually to adjust settings and have reset router back as AP to get back up and running in short term.
Not sure where I am going wrong, any more advise would be greatly appreciated.
Dec 02, 2020Guru - Experienced User
options?
1. Try the above
- bearaceDec 09, 2020Tutor
Thanks for the advise. Sorry its taken so long to respond. Unfortunately my network goes down for several hours or days when I start trying to fix this issue. Still not able to connect as I would like. Have left it in a double NAT configuration at the moment which is functioning OK. Just connot see the Telstra modem on the network. If we have a power outage will be fun to see how it restarts
