AngeryMikey
Dec 20, 2020Follower
Connecting Nighthawk RAX48 with Centurylink C3000Z
I recently purchased a RAX48 router to hook into my Centurylink C300Z. I had been using the Centurylink as a modem/router, but want to now use it only as a modem and the RAX48 as the router. The Nigh...
Dec 21, 2020Guru - Experienced User
Its challenging because they use different nomenclature for the same/similar things.
Bridge mode for routers typically means using its wireless as a bridge between it and another router. It doesn't re-broadcast. Which is why they say don't use it.
For modem/router combo devices its usually refered to as pass through/modem only mode. Some call it bridge mode which makes it confusing. Search for putting the C3000Z in passthrough mode. That typically is the mode you want for the C3000Z so the RAX can function as a router without double nat issues.
