tommy0629
May 01, 2023Aspirant
Connecting Nighthawk RAX54 to Samsung Galaxy S21 Ultra to use USB tethering
Hi everyone. Need help configuring T-Mobile Galaxy S21 android phone to use USB tethering for my RAX54 router. Thank you. Tommy
May 01, 2023Guru - Experienced User
Something to contact T-Mobile or Samsung about.
I don't think USB tethering is supported since the USB port on the router doesn't support any internet services. The RAX router requires use of the WAN port connected to a ISP modem or ONT for it's internet services.
tommy0629
May 02, 2023Aspirant
Furrye38:
Thanks for your suggestion and comment. đ
I'm happy to report that I'm connected to the Internet via an ARGOM Tech USB-C to RJ-45 Network Cable Adapter (dongle) connected to the Type-C female connector in my Samsung Galaxy S21 Ultra and using the standard Ethernet tethering option of the phone software. That is all I wanted. Thanks for your time. BTW, Nice setup you have. Chhers. Tommy
- FURRYe38May 04, 2023Guru - Experienced User
Good to know. Glad that works.
Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. đĄ
