ifli2
May 07, 2020Follower
Connecting RAX120 to Vera Z Wave
Just replaced my Asus AC2400 with the Night Hawk RAX120 to improve WiFi connections and very impressed with double speed on the iPhone 11s. The set up on the mobile app went well and using the previ...
Christian_R
May 12, 2020NETGEAR Employee Retired
Hello ifli2,
You may try disabling AX mode on the router's settings to see if that would help. Furthermore, if you recently purchased the device, please note that your device is provided with 90 days of complimentary support from our support team which you may access using the link below.
https://www.netgear.com/support/default.aspx
Christian
