JimmyW
Mar 01, 2024Luminary
Connection fails to maintain auto-login and periodic loss of connection
I'm running Win 11 and set my wi-fi to login automatically to my chosen network. Recently, the auto-login stopped working and I must select my network and login manually every time I start up. Also, ...
JimmyW
Thanks. Windows only allows one network to be checkedmarked. So, I had checked the 2.4 band. Later, I checked the 5.4 band. to test that connection. When I go to log back in to the 2.4, it shows a message under the password box of "Some information changed since the last time you connected. We need additional information to complete the connection." Perhaps that simply means it needs my password; I don't know, but the 5.4 doesn't require anything further.
JimmyW
Mar 02, 2024Luminary
I think you nailed it. Network is still working as it should.
