eforbell
Mar 03, 2024Aspirant
Connection is dropped to WAN precisely at 4am ET (for my timezone) and no WiFi
Had this started to happen about a week ago with a Nighthawk RAX50v2. Connection is dropped to WAN precisely at 4am ET (for my timezone) and no WiFi or DHCP is running either - all hosts are disconn...
eforbell
Mar 04, 2024Aspirant
My mistake on red light, only when I have to reboot via push switch every morning when I wake up. When I find the device in mornjng all white lights, essentially.
Re: time of shutdown - I run services that are always on and require WAN access and their logs indicate drops at precisely 4AM ET every day. unfortunately I’m recovering from a flu and haven’t had opportunity to noodle much more.
I suspect some incomplete firmware push. A little over a week ago was prompted to update and tried and the router never rebooted but also no network either. Reboot got me back to 1.1.3.18. I should have never updated firmware - usually more trouble than worth when device is performing fine. I will exhaust all troubleshooting steps prior to a factory reset. Will try manual firmware load from web admin console.
eforbell
Seems as if the router’s GUI in admin console got a significant update. *many* more settings and even things like scheduled wireless signal on / off times. All schedules are not set and disabled, but very intriguing. I also have Ethernet connected devices that get connectivity dropped so that feature alone malfunctioning wouodnt explain this.
