waverunner1
Jan 05, 2021Aspirant
Connection Issues Nighthawk Mk 62 AX 1800 Mesh
I appreciate the help on my last post. The issue was integration between my Netgear AX 1800 mesh and an AT&T 5268 router with gigabit service. I have tried several configurations and here is whe...
Christian_R
Jan 11, 2021NETGEAR Employee Retired
Hello waverunner1,
If you recently purchased the device I would recommend contacting our support team as newly purchased devices are provided with 90 days of complimentary support. You may open a ticket by registering your device using the link below.
https://www.netgear.com/support/contact.aspx
Christian
waverunner1
Jan 14, 2021Aspirant
And just like that, it's gone again. Today, the iPhones, Amazon Alexa, 2 Chromebooks and an HP laptop all cannot connect to the wifi.
Amazing. I think it's time to return the Netgear. I've had enough.
