DarthGoblin
Mar 01, 2022Follower
Connection keeps dropping RAX20
I just bought and moved into a new home that is a condominium located in a small complex. Not a while lot of internet options here but all of the options use a modem located outside the building that ...
Mar 02, 2022Guru - Experienced User
Netgear has set up a community forum specifically for the NightHawk RAX WiFi 6 Router products. Most of the people who watch that forum are more likely to have experience with NightHawk (WiFi6 RAX and RAXE Series) router products. Might be more likely to find someone who has a solution if the question is posted there:
https://community.netgear.com/t5/Nighthawk-Routers-with-WiFi-6-AX/bd-p/en-home-routers-nighthawk-wifi-ax6
Thank you.
