200DF7
Oct 18, 2019Aspirant
Connection loss with Xbox party
This router has spent more time in the box than in use. I have done an absurd amount of reading this forum for answers to no avail. The problem: I have 4 xbox's and everytime my son connects to his...
michaelkenward
Oct 19, 2019Guru - Experienced User
A community search on Xbox might help. These things are a cause of constant complaints.
Search - NETGEAR Communities – Xbox
Search - NETGEAR Communities – Xbox party
What firmware version do you have on the device?
A number is more useful than "the latest". (It may not be by the time people read this.) There can also be newer versions, or "hot fixes", that do not show up if you check for new firmware in the browser interface.
It might also help if you told people what the modem is in front of this router. The model number could be useful. Is it, by any chance, also a router, with a set of LAN ports on the back?
- 200DF7Oct 19, 2019Aspirant
Thank you for the reply, I have combed through those communities heavily.
The Router:
Firmware Version V1.0.1.64_1.0.27
The Modem: CM1000
Firmware Version V5.01.04
- michaelkenwardOct 19, 2019Guru - Experienced User
200DF7 wrote:
The Modem: CM1000
That's good. Modem only. It rules out the possibility of clashing routers.
There nothing that you can do about its firmware.
200DF7 wrote:
The Router:
That's the latest, but that may not be the best idea. These RAX boxes aren't loved by everyone. Some people have had better luck with older firmware. But that wasn't related to the same issue that you flagged up.
