JonesMan
Aug 11, 2023Follower
Connection of ax12 (RAX120) only via IPv6 or DS-lite
Hi,
my new ISP provided only DS-Lite. Is there any chance to establish an internet connection over that standard? So far my investigation turnedd up different results (that there have been bugfixes in the firmaware for DS-Lit in Japan and that this is not a supported feature for the AX12).
Anyhow if DS-Lite is not supported are there any Netgear devices possesing that feature? Or are there any plans to implement it in further firmware updates for the AX12?
Thanks
1 Reply
NG doesn't say if and or when if new features are forth coming. If DS-Lite isn't supported on NG routers, you may need to find something that does. Ask the ISP what they recommend.
