CorvusLutra
Jan 13, 2021Tutor
Connection problems and "WLAN access rejected: incorrect security" in logs
Hi - I'm having a lot of problems with an RAX20 (which isn't an option in the "Model" field, for some reason, so I chose the closest match. Firmware version is 1.0.2.64_2.0.42.) in Access Point mode....
Jan 13, 2021Guru - Experienced User
Which arris touchstone is it? there should be a model on it?
Have you tried the arris in bridge/modem only mode and using the RAX in router mode?
CorvusLutra
Jan 13, 2021Tutor
Hi - the router's a TG2492LG. I'm not using it in bridge mode as I lose the use of its other Ethernet LAN ports.
