CorvusLutra
Jan 13, 2021Tutor
Connection problems and "WLAN access rejected: incorrect security" in logs
Hi - I'm having a lot of problems with an RAX20 (which isn't an option in the "Model" field, for some reason, so I chose the closest match. Firmware version is 1.0.2.64_2.0.42.) in Access Point mode....
Jan 13, 2021Guru - Experienced User
Which arris touchstone is it? there should be a model on it?
Have you tried the arris in bridge/modem only mode and using the RAX in router mode?
I'd try it in bridge/modem only mode and the RAX in router mode. If it fixes the issue, then you can always get a cheap gigabit switch if you need more ports on the rax.
