alfraed
Sep 27, 2021Aspirant
connection refused
Salve a tutti, la mia configurazione è la seguente: modem Wind3 HUB router rax120 collegato al modem tramite porta wan, ad esso sono collegati 2 hard disk usb, switch netgear POE GSM4210P 8 por...
Sep 27, 2021Guru - Experienced User
In inglese per favore
alfraed
Hello everyone, this is my setup:
modem Wind3 HUB
router rax120 connected to the modem with wan port, 2 usb HDD
switch netgear POE GSM4210P 8 ports connected to router with 5gbit port,
switch netgear nighthawk gs810 emx 10 ports connected to GSM4210p switch poe with 5gbit port,
N.2 access point netgear eax20 both connected to gs810
I can't access to rax120 admin page since 1 month, all connected devices worked properly, i had access on both switches and access point, today i tried to reset RAX120 but i cant connect , i tried to connect only the PC directly to the router but no way....my browser says connection refused
Model: RAX120|Nighthawk AX12 12-Stream WiFi Router
Message 1 of 2
