Bronwen
Jan 23, 2022Aspirant
Connection to internet
Some apps update with WiFi. Other apps need mobile data to update, sometimes. Why?
Bronwen
Jan 24, 2022Aspirant
Netgear AC 1900, D7000v2, modem router.
I have a Dell desktop, windows 11, no problems. My mobile phone S21 Ultra 5G sometimes has problems with mobile data connection to internet. At home, it connects to the netgear wifi. Sometimes I cannot update some Apps via the wifi & have to turn on mobile data. The Google news and ABC Australia News apps are trhe main problem. Wifi will not update, but mobile data will.
Jan 24, 2022Guru - Experienced User
Bronwen wrote:
Netgear AC 1900, D7000v2, modem router.---and are you using it on dsl or do you have it connected to something else?
Firmware on it?
- BronwenJan 24, 2022AspirantDesktop Netgear(modem, router) go through NBN. I am using mobile phone & just now WiFi did not work & had to go through mobile data ???
- plemansJan 25, 2022Guru - Experienced User
Bronwen wrote:
Desktop Netgear(modem, router) go through NBN.----all that tells me is that you're in australia. NBN is national broadband network for australia. It encompases everything from dsl, to fibre to the curb, fibre to the home, fixed wireless, satellite, ETC.It doesn't tell me what service you have or how the D7000 is connected to it.
sorry, last post went wonky.
NBN is just a term for australia's internet. it doesn't tell me what service you have, how you're connected to it, etc. Details are key
