MWW's avatar
MWW
Follower
Jul 15, 2020
Connections to RAX200 - best practices
I have the CM1150v cable modem and the AX11000 router.  Also an AX Mesh type Range Extender but that's another topic.
I have a NAS server which supports link agregation.  Certainly my modem does as well.  I also have the a NetGear 24-port switch.
So, how do I arrange all this?  I can't even figure out how to connect the router to the cable modem using multi-gig or the 2.5 gig.  The quick start guide is worthless.
Do I plug my NAS server into the router using link-agregation, or into the switch using link-agregation?  Do I connect the switch to the router using link-agregation?  It's the JGS-524.
So, certainly CM1150v --> RAX200 (AX11000) --> JGS-524.  But where to plug in the NAS server?  And can I get ALL of these to support speeds faster than 1Gig?
I would also like to hard-wire the AX range extender to free up WiFi band-width, but don't think that's an option.
No RepliesBe the first to reply
