emmijackson
Dec 18, 2023Tutor
Connectivity issues with my RAX80
I've encountered similar connectivity issues with my RAX80, even after updating to the latest firmware. Random disconnections are affecting my streaming and web browsing. Despite trying reboots, the ...
- Dec 18, 2023If DoS protection is enabled, it may be the cause. Disable it and see if disconnections go away. Just a thought...
emmijackson
Dec 18, 2023Tutor
"I've encountered similar connectivity issues with my RAX80, even after updating to the latest firmware. Random disconnections are affecting my streaming and web browsing. Despite trying reboots, the problem persists. Has anyone discovered a solution or faced the same issue? I'm a bit reluctant to do a factory reset at this point. Any insights would be greatly appreciated!"
