emmijackson
Dec 18, 2023Tutor
Connectivity issues with my RAX80
I've encountered similar connectivity issues with my RAX80, even after updating to the latest firmware. Random disconnections are affecting my streaming and web browsing. Despite trying reboots, the ...
- Dec 18, 2023If DoS protection is enabled, it may be the cause. Disable it and see if disconnections go away. Just a thought...
Dec 18, 2023Guru - Experienced User
Be sure your using a good quality LAN cable between the modem and router. CAT6A STP is recommended.
What channels are you using? Try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
Armor, Smart Parental Controls or Circle, Traffic Meter.
If all else fails, Factory reset and a complete pull of the power adapters for a period of time after the factory reset then walk thru the setup wizard and setup from scratch with a wired PC and web browser. https://kb.netgear.com/22697/How-do-I-install-my-NETGEAR-router-using-the-router-web-interface
Recommend setting the default DHCP IP address pool range to the following after applying and a factory reset: 192.168.#.100 to 192.168.#.200.
https://kb.netgear.com/24089/How-do-I-specify-the-pool-of-IP-addresses-assigned-by-my-Nighthawk-router
https://kb.netgear.com/25722/How-do-I-reserve-an-IP-address-on-my-NETGEAR-router
I would power OFF the ISP modem for 1 minute. Factory reset the router and power it off. Power ON the ISP modem and let it sync. Then power ON the router and walk thru the setup wizard again using a wired PC and a web browser.
Press the back reset button for 10 seconds then release.
https://kb.netgear.com/9665/How-do-I-perform-a-factory-reset-on-my-NETGEAR-router
Or use the ERASE button on the routers web page to factory reset the router:
https://kb.netgear.com/24233/How-do-I-erase-the-configuration-settings-on-my-Nighthawk-router
- microchip8Dec 18, 2023MasterIf DoS protection is enabled, it may be the cause. Disable it and see if disconnections go away. Just a thought...
- emmijacksonDec 18, 2023Tutor
wow it works, thanks man.. greatly appreciated.
- FURRYe38Dec 18, 2023Guru - Experienced User
Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
