emmijackson
Dec 18, 2023Tutor
Connectivity issues with my RAX80
I've encountered similar connectivity issues with my RAX80, even after updating to the latest firmware. Random disconnections are affecting my streaming and web browsing. Despite trying reboots, the ...
- Dec 18, 2023If DoS protection is enabled, it may be the cause. Disable it and see if disconnections go away. Just a thought...
microchip8
Dec 18, 2023Master
emmijackson
Dec 18, 2023Tutor
wow it works, thanks man.. greatly appreciated.
- FURRYe38Dec 18, 2023Guru - Experienced User
Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
