EdgarSanson
Aug 19, 2022Aspirant
connectivity Problem with My RAX50
Having Connectivity problems with my RAX50 since the last update any recommendations please
EdgarSanson
Aug 22, 2022Aspirant
Thank Michel For the answers
Not much to go on there. Update from what to what? Update Netgear Firmware Version 1.0.10.110 to Firmware Version 1.0.10.112
What Connectivity problems? When i do the traceroute command the process is not compleated.
The thing won't get on to the Internet? I have internet connection but I'm having cut off very often
This is one example of the traceroute command:
traceroute to (64.239.246.185), 64 hops max, 52 byte packets
1 192.168.68.1 (192.168.68.1) 1.647 ms 0.819 ms 0.745 ms
2 38.133.49.161 (38.133.49.161) 8.220 ms 11.784 ms 9.562 ms
3 10.170.192.53 (10.170.192.53) 10.816 ms 10.985 ms 10.077 ms
4 38.102.66.129 (38.102.66.129) 9.320 ms 9.390 ms 9.797 ms
5 * * *
6 be2089.ccr21.ymq01.atlas.cogentco.com (154.54.45.113) 13.190 ms 11.718 ms 9.808 ms
7 motl-b2-link.ip.twelve99.net (80.239.161.148) 11.325 ms 12.382 ms 10.918 ms
8 chi-b23-link.ip.twelve99.net (62.115.118.188) 31.164 ms 29.796 ms 31.207 ms
9 viawest-ic350579-chi-b23.ip.twelve99-cust.net (62.115.181.145) 28.958 ms 31.319 ms 28.704 ms
10 be23.bbrt01.chi10.flexential.net (148.66.237.220) 55.043 ms 52.973 ms 56.452 ms
11 be204.bbrt02.cin01.flexential.net (148.66.239.28) 53.942 ms 56.040 ms 53.361 ms
12 be205.bbrt02.iad10.flexential.net (148.66.239.24) 56.443 ms 54.315 ms 54.802 ms
13 be10.bbrt01.iad10.flexential.net (148.66.239.22) 55.516 ms 55.888 ms 55.270 ms
14 be209.bbrt02.ral01.flexential.net (66.51.5.117) 56.592 ms 52.981 ms 54.788 ms
15 be32.crrt02.ral01.flexential.net (148.66.238.113) 53.447 ms 54.207 ms 51.848 ms
16 64.239.246.185 (64.239.246.185) 56.332 ms 53.349 ms 54.826 ms
17 * * 72.15.242.133 (72.15.242.133) 1047.621 ms !H
18 * * *
19 * * *
20 * * 72.15.242.133 (72.15.242.133) 1678.073 ms !H
21 * * *
22 * * *
23 * * *
24 * * *
25 * * *
26 * * *
Something else?
What firmware version do you have on the device? Firmware Version 1.0.10.112 last version
It might also help if you told people what the modem is in front of this router. Yes There is a Modem in from of this router the tecnicolor model TC4400-AM.
Is it, by any chance, also a router, with a set of LAN ports on the back? No this modem is not a router.
The reason for asking is that a lot of people turn up here trying to put a router behind a modem that is also a router. That can complicate troubleshooting. Is not may case
Check for various troubleshooting tips.
You may have done this already. I can't tell from your message. Yes all Done but no answers to my problem.
I mention it because Netgear stopped supplying printed manuals and CD versions some years ago and people sometimes miss the downloads.
