Lapidus
Aug 19, 2019Tutor
Constant disconnects on Surfacebook 2 AX40 -
I purchased an AX4 router. All other devices in my home work on it fine without disconnection issues. My surfacebook 2 laptop constantly disconnects, be it on the 2.4ghz or 5ghz network. It is variab...
yddtime
Aug 20, 2019Luminary
It could be this:
Latest Surface Pro 6 and Book 2 Updates Are Causing CPU Throttling and WiFi Issues
https://wccftech.com/latest-surface-updates-causing-cpu-throttling-and-wifi-issues/
Do Not Install Your Microsoft Surface's August Firmware Updates
https://lifehacker.com/do-not-install-your-microsoft-surfaces-august-updates-1837281948
Lapidus
Aug 20, 2019Tutor
Hmm. Just tried rolling back the driver. Will let you know how it goes. Re connecting and disconnecting the network. Didn't do anything.
Will be hard to say if the old driver works right away. Just did it. Will give it a day or two (or until the first disconnection) and get back.
