Lapidus
Aug 19, 2019Tutor
Constant disconnects on Surfacebook 2 AX40 -
I purchased an AX4 router. All other devices in my home work on it fine without disconnection issues. My surfacebook 2 laptop constantly disconnects, be it on the 2.4ghz or 5ghz network. It is variab...
Lapidus
Aug 24, 2019Tutor
Rolled back drivers. Tried forgetting network. Nothing works. This router does NOT work on a surfacebook 2 laptop and by the looks of other people posting on the internet, does not work with most microsoft surface products.
I am going to have to buy a usb wifi card to get this to work since I do not have money to buy a mesh network as I spent it all on modem + router already.
Would be nice if netgear would comp all surface owners a usb wifi card. Or at least warn on the box that the devices are not compatible with surface products.
Christian_R
Aug 26, 2019NETGEAR Employee Retired
Hi Lapidus - I'd like for our support team to reach out to you for further investigation. If you're interested, please send me a message with your contact info.
~Christian
- EKol00Dec 08, 2019Aspirant
I have the exact same issue with my Surface Pro 6.
Is there a way to resolve this??
thanks.
- LapidusDec 09, 2019Tutor
i had to purchase a usb modem. annoying.
also the update microsoft pushed out a month ago or so helped a little bit
- nengeDec 17, 2019Aspirant
Same issue with the Surface Pro 5. Very frustrating.
- Christian_RDec 18, 2019NETGEAR Employee Retired
Hi nenge,
Have you gotten a chance to check to see if your Surface Pro 5 is due for a WiFi driver update?
Christian
