nichbankston
Mar 14, 2020Aspirant
Constant packet loss
Ok so originally I have the R8000P model and one day I recieved huge packet loss of 80% no matter what I did. Factroy reset, reinstall firmware, wired and wireless received horrible packet loss. So I...
nichbankston
Mar 15, 2020Aspirant
Im currently using the Arris sb8200 Modem, Sorry I should have mentioned that I replaced this aswell. I used the warranty on both at bestbuy to get a brand new modem and upgrade my router at the same time just to make make sure. I've been runnign traceroute on pingplotter for a week now and i see about 15-40% packet loss throughout the day. Ive done everything possible and researched this for a week straight.
facytory reset modem and router last night and the packet loss got down to 2% and ran fine all last night. Woke up and bam, back to horrible levels.
nichbankston
- plemansMar 15, 2020Guru - Experienced User
what happens if you direct connect to the modem?
- nichbankstonMar 15, 2020Aspirant
I Still receive packet loss but on a much lower scale. I tested it and I get about 1-3% packet loss. I know my internet provider is meh buit it's all I have.
Howeer when plugged into the router I recieve upwards or 75% even saw 80% at one point. It's inconsistantly consistant, by that I mean I have consistant Packetloss and ping spikes, but not consistant in its pattern or jitter.- plemansMar 16, 2020Guru - Experienced User
do you have a different pc you can try?
Reason I ask is that you've replaced the modem and the router and had the same results. So try checking the pc/cables/connections next.
