theblueray
Jul 27, 2021Aspirant
Copy old settings to a RAX200
Hello how can I copy settings from a R8000 to a RAC200? I’ve tried the operation from save to from restore to but seems that is not possible.……
If I backup the RAX200 settings and then restore to itself it work….. 🤔
Thanks in advance
Oscar
Thanks in advance
Oscar
> Hello how can I copy settings from a R8000 to a RAC200? [...]
Record your R8000 settings (it's easier if you do it when you make
the changes), and make the corresponding changes on the RAC200?
Otherwise, no.> [...] I've tried the operation from save to from restore to but seems
> that is not possible. [...]"seems"?
Different hardware, different firmware, non-portable file format.
> [...]Same hardware, same/compatible firmware. Different situation.
- thebluerayAspirantHello. Your reply is clear. I will try to insert settings manually. Thanks again. Oscar
