spacecoms's avatar
spacecoms
Follower
May 14, 2019
Country of Origin for RAX120 Nighthawk AX12
What is the Country of Origin for the Netgear RAX120 Nighthawk AX12?
  • kc6108's avatar
    kc6108
    May 15, 2019
    The bottom of the RAX120 box that I have here shows "Made in Taiwan". FYI, the router was purchased in the USA.
  • Christian_R's avatar
    Christian_R
    NETGEAR Employee Retired
    Hi spacecoms - You can find the Country of Origin on the bottom of the RAX120 package.
    ~Christian
    • kc6108's avatar
      kc6108
      Luminary
  • michaelkenward's avatar
    michaelkenward
    What do you mean by "country of origin" and why are you asking?
    The country of manufacture is not the same as the country that Netgear sets as the sales country.
    The model number on the box will tell you where the unit was meant to be sold. There is a suffix after the RAX120 that tells you this. -100UKS says UK, while -100NAS = North America.
    That code can be important because it will tell you what the configuration is for things like wifi. Stuff sold into the USA may be locked on to wifi channels that are illegal in other countries, and vice versa.
    • schumaku's avatar
      schumaku
      1999: My router is connecting to IP addresses in Russia and in China.
      2019: The device does contain a Chinese spy processor.
