Retired_Member
May 03, 2024Crazy Problem
I recently went to AT&T 5G Air for my Internet. Problem is VPN's will not work with their Router and the speed goes down to very close to nothing. I can connect my Nighthawk Model RAX70 to the AT&...
May 03, 2024Guru - Experienced User
in my experience, its not going to change the speed because the bottleneck is the att device.
You're always welcome to try it
