Retired_Member
May 03, 2024Crazy Problem
I recently went to AT&T 5G Air for my Internet. Problem is VPN's will not work with their Router and the speed goes down to very close to nothing. I can connect my Nighthawk Model RAX70 to the AT&...
Kitsap
May 03, 2024Master
Retired_Member wrote:I recently went to AT&T 5G Air for my Internet. Problem is VPN's will not work with their Router and the speed goes down to very close to nothing. I can connect my Nighthawk Model RAX70 to the AT&T Router by cable and I am wondering since I will be connected to my Nighthawk Router if I will once again be able to use a VPN. Thanks for any help or suggestions.
Information on configuring the AT&T fixed wireless devices appears to be scarce. You are looking for documents on how to configure the device for bridge mode to allow use of your router. The documents are available only to the account holders.
