Gogat's avatar
Gogat
Follower
Jun 14, 2022
Create a mesh between Ruckus and Nighthawk
Hello,
I (think I) am looking to create a mesh network so that I can extend the range of a LAN. It will not be connected to the internet, just to my computer which will provide the data for other computers on the network.
Setup as follows:
Computer > Nighthawk Triband AX8 Rax70 (Ethernet port 1) > a POE power pass through (from Ethernet 2)> Ruckus R710 Access Point.
Again, I would, ideally like for them to share the same SSID so that any computer that connects will get the best strength based on signal rather than the user having to choose which one to connect to.
Is it possible? Any help is appreciated. Thanks in advance.
No RepliesBe the first to reply
