PeteDog
Dec 16, 2020Star
Current RAX120 firmware version
The web site download page shows the current firmware version as 1.0.2.136. This morning I checked using the phone app, and it shows a version 1.2.0.16 available. Installed OK but want to verify th...
PeteDog
Dec 16, 2020Star
Update 2....
Appears the flakey web site issues were due to problems with Quad9 DNS which I use. That seems to be resolved now.
Still have the original question about the current firmware version for an RAX120....
Thanks
Blazerichmond
Dec 16, 2020Initiate
Got the same thing on mine. Appears it auto updated the firmware overnight Dec 15th-16th to 1.2.0.16. Now the performance is poor. App states it is offline although I have reset everything twice and reset up the router completely. Most devices in the house state there is no internet through the router.
- PeteDogDec 16, 2020Star
Yeah, I downgraded back to the previous version (listed as current on the download support page). I did have to manually reconnect some devices each time.
- soeunDec 16, 2020Apprentice
1.2.0.16 made all my ports on my RAX120 not able to connect to internet. Can only reach internet via WIFI. All my cables are fine. I am now going to attemp to go back to 1.0.2.136.
- AVLTechDudeDec 16, 2020Tutor
Mine says a new firmware version is available, but fails to download it and says "check your Internet connection." The 1.2.0.16 version is not available for download on the Support page for the RAX120. They may have realized it causes issues and pulled the update, but the auto firmware check still seems to think there is an update available. From the reports thus far, I'm glad mine hasn't auto updated. I'll wait for the next version.
