PeteDog
Dec 16, 2020Star
Current RAX120 firmware version
The web site download page shows the current firmware version as 1.0.2.136. This morning I checked using the phone app, and it shows a version 1.2.0.16 available. Installed OK but want to verify th...
Quigley_Wyatt
Dec 16, 2020Tutor
Same issue - auto updated overnight to V1.2.0.16 which broke wired connections. Manually fell back to 1.0.1.128 which fixed everything again. I've turned off firmware auto-update since the router is still indicating that V1.2.0.16 is an update that needs to be installed.
- Quigley_WyattDec 16, 2020Tutor
Correction - fell back to V1.0.2.136
- mfinazzoDec 27, 2020InitiateMy router did the same auto update to the new firmware and now it won’t even boot up. How can I convert back to a previous version.
- NewfiedroolDec 16, 2020Virtuoso
It will pay to factory reset after updating back to the current listed firmware just to be nice and safe.
- TopologyDec 16, 2020Virtuoso
What are the release notes for the V1.2.0.16 firmware?
Thank you.
It's not listed on the support page as I believe they have issued the wrong firmware.
