PeteDog
Dec 16, 2020Star
Current RAX120 firmware version
The web site download page shows the current firmware version as 1.0.2.136. This morning I checked using the phone app, and it shows a version 1.2.0.16 available. Installed OK but want to verify th...
Quigley_Wyatt
Dec 16, 2020Tutor
Same issue - auto updated overnight to V1.2.0.16 which broke wired connections. Manually fell back to 1.0.1.128 which fixed everything again. I've turned off firmware auto-update since the router is still indicating that V1.2.0.16 is an update that needs to be installed.
Newfiedrool
Dec 16, 2020Virtuoso
It will pay to factory reset after updating back to the current listed firmware just to be nice and safe.
- TopologyDec 16, 2020Virtuoso
What are the release notes for the V1.2.0.16 firmware?
Thank you.
- NewfiedroolDec 16, 2020Virtuoso
It's not listed on the support page as I believe they have issued the wrong firmware.
- Christian_RDec 16, 2020NETGEAR Employee Retired
Hello AX Community Users,
I can confirm that firmware v1.2.0.16 is indeed for the RAX120 and should be available on the support site soon along with the release notes. You may proceed with the update through the GUI or Nighthawk app.
Thank you for looping me in Newfiedrool
Christian
- AVLTechDudeDec 16, 2020Tutor
Christian_R any comment on the reports from multiple others that installing 1.2.0.16 breaks wired connections? Is there anything in the release notes about a change required after installation? I can't afford to install it and break wired connections and be unable to work tomorrow. Thank you.
