PeteDog
Dec 16, 2020Star
Current RAX120 firmware version
The web site download page shows the current firmware version as 1.0.2.136. This morning I checked using the phone app, and it shows a version 1.2.0.16 available. Installed OK but want to verify th...
Newfiedrool
Dec 16, 2020Virtuoso
It will pay to factory reset after updating back to the current listed firmware just to be nice and safe.
Topology
What are the release notes for the V1.2.0.16 firmware?
Thank you.
- NewfiedroolDec 16, 2020Virtuoso
It's not listed on the support page as I believe they have issued the wrong firmware.
- Christian_RDec 16, 2020NETGEAR Employee Retired
Hello AX Community Users,
I can confirm that firmware v1.2.0.16 is indeed for the RAX120 and should be available on the support site soon along with the release notes. You may proceed with the update through the GUI or Nighthawk app.
Thank you for looping me in Newfiedrool
Christian
- AVLTechDudeDec 16, 2020Tutor
Christian_R any comment on the reports from multiple others that installing 1.2.0.16 breaks wired connections? Is there anything in the release notes about a change required after installation? I can't afford to install it and break wired connections and be unable to work tomorrow. Thank you.
- avtellaDec 16, 2020Prodigy
The new firmware on my RAX120 no longer lets me select United States for Wireless and only options are Australia/Europe/Korea/Hong Kong/Singapore.
- KiseraiDec 16, 2020Tutor
Christian_R wrote:Hello AX Community Users,
Christian
Did...did you read the thread?
Unless those release notes indicate that disabling the internet connection to every ethernet port was intentional, you might want to take that firmware update back to the drawing board.
I would highly recommend that anybody reading this avoids v1.2.0.16 like the plague.
- avtellaDec 16, 2020ProdigySeems like some clients like my AppleTV 4K seem to have massive latency/jitter on 2.4 GHz when the router has AX enabled, so it looks like there’s some issue with fall back to N mode. Didn’t have this issue with previous firmwares. I alway factory restore after an update so I’m confident it’s a new firmware bug.
